Question about antannae lead length.
  • Thread starter Thread starter Deleted member 120647
  • Start date Start date
D
Guest
I have seen various 'proper' range extending antennae and most seem to use screw on leads to connect the antennae to the controller. I have also seen antennae advertised as suitable for mounting, via a suction cup, on a car roof or bonnet whilst the pilot and controller are inside the car. Again screw on leads are used to connect the antennae to the controller but they are long.
This got me to wondering, is the length of such leads critical and matched to the antennae?
My VERY limited understanding of radio transmitters and receiver suggests the length of the antennae is connected to the wavelength of the intended radio waves so I am wondering if the same applies to the leads.
The leads are not part of the tuned section and do not alter the matching. However the length and number of connections does create signal loss. Keeping the leads short and with few connections is best.
Ta, do you know if these leads are "sheathed" akin to co-axial cable?
Nearly all antenna cables are coaxial, so Yes.
In practice antennas are typically less than a full wavelength due to [physical] practicality.
The most common fractions are 5/8, 1/2 & 1/4.
