PV2 camera vision delay
After reading about the PV2 before i purchased it, it said the camera had a 1/10th sec delay. Now that i have the PV2 the delay in vision is about 3 or more seconds. Anyone else have this issue?
yep. I think it's something to do with the latest update. Also may depend upon the version of app you're running. btw, where did you see it stated that delay was 1/10th of a second?
Hope this helps
Bmews
Hope this helps
Bmews
It in the overview section of the PV2 sale page on websites. But it might mean 1/10th second if your panning the camera or the like.
38Special said:
Yes, a few threads about it with the new app. Lower your frame rate to 15 from 30. It solved it on mine.
Gday mate, i looked on the iphone app to change the frame rate but could not find it. Where is it located?
Under settings and preview
Thanks mate,
But if i want to shoot in 1080p im stuck with whatever it says? Isn't 640x480 15fps and 320x240 15fps a much lower quality movie?
007trains said:
Thats just the preview quality not the actual recording
Got ya mate, Thank you. So by doing this what i see on the iphone should be almost realtime from the PV2/
Depends on your phone's processing speed, too - but generally yes. The CPU in older phones like - iPhone 4 - sometimes can't decode & display the Vision's preview video in real-time unless you lower the preview resolution to 320 x 240. Newer phones are faster at this.
EDIT: Just speculation, but I'd guess the DJI Vision app doesn't offload video processing to your phone's GPU - which is why playback is so dependent on your phone's CPU speed.
Download the latest app, and in the setting, under preview quality, which item are you choosing ? They added one higher resolution and made it as default. Maybe that resolution is too big for your phone to decode in realtime.
Thanks for that info fellas. I am using a Iphone 4S but got an ipad mini today. I'll lower the preview on both devices and see how it goes. Thanks for your help.
jack klausner
