BMEWS said:yep. I think it's something to do with the latest update. Also may depend upon the version of app you're running. btw, where did you see it stated that delay was 1/10th of a second?
Hope this helps
Bmews
38Special said:Yes, a few threads about it with the new app. Lower your frame rate to 15 from 30. It solved it on mine.
Gday mate, i looked on the iphone app to change the frame rate but could not find it. Where is it located?38Special said:Yes, a few threads about it with the new app. Lower your frame rate to 15 from 30. It solved it on mine.
michaeljp said:Gday mate, i looked on the iphone app to change the frame rate but could not find it. Where is it located?38Special said:Yes, a few threads about it with the new app. Lower your frame rate to 15 from 30. It solved it on mine.
FlyingFox said:michaeljp said:Gday mate, i looked on the iphone app to change the frame rate but could not find it. Where is it located?38Special said:Yes, a few threads about it with the new app. Lower your frame rate to 15 from 30. It solved it on mine.
Under settings and preview
007trains said:Thats just the preview quality not the actual recording
Depends on your phone's processing speed, too - but generally yes. The CPU in older phones like - iPhone 4 - sometimes can't decode & display the Vision's preview video in real-time unless you lower the preview resolution to 320 x 240. Newer phones are faster at this.michaeljp said:007trains said:Thats just the preview quality not the actual recording
Got ya mate, Thank you. So by doing this what i see on the iphone should be almost realtime from the PV2/
michaeljp said:After reading about the PV2 before i purchased it, it said the camera had a 1/10th sec delay. Now that i have the PV2 the delay in vision is about 3 or more seconds. Anyone else have this issue?
