I didn't change anything. Mine just works providing I've calibrated recently. No idea if its important or not but I'm always stood behind it facing the same way as the quad when I power on.wetauser said:yes I calibrate the compass regularly , my problem is that the phantom direction arrow in radar is about 90 degrees off , if I use iPad the direction is correct, what did you change to get correct reading on the Moverio?
I agree about the ground station far easier to use mobile device.
Not sure how they would work with the none vision as you need to run an android app on the glasses to see a video feed. If your setup has an app that runs under android ICS then no reason why they shouldn't work.auen1 said:A few questions.
Do they work with a P2 non-V?
If the glasses are off, are they clear to see through?
How long does the battery typically last on a full charge?
Also, using in dark situations, is light flashing off your face?
And should I try to get the R or the D version?
Thanks, these seem pretty darn cool.
wetauser said:I found out this morning that the arrow on the radar points where I want, just by moving my head,must be though the head tracking,thought it strange that direction arrow worked some but not all .
Cannot find how to disable head tracking anybody know?
wetauser said:wetauser said:I found out this morning that the arrow on the radar points where I want, just by moving my head,must be though the head tracking,thought it strange that direction arrow worked some but not all .
No one else noticed this,am I the only one? if I sit behind the PV2+ looking at it and move my head up and down(not side to side) the drone direction arrow moves from side to side, flips between 270 degrees and 90 degrees. compass arrow also moves.
This makes this feature useless.
I have the R version of the glasses
