problems after fw update
Finland
Hi, cant get any answers at dji forum, so im gonna ask some here
What's the latest fw for 4k ? How do i update it, just like standard or like pro/adv ? (standard is app only update?)
If like standard then how, because it doesnt show that it needs updating.
Link in dji forum Problems after update
Maybe somebody can help me with that live video thingy
No nothing useful on those links. Update log on dji forum link (I dont have a pc right now to copy it here easily)
It was fine before the update. Yes on short distance, it loses connection for fpv in 20m.
Finally found some I dont know documents? for 4k and I have the latest fw
Yesterday got to see my recorded videos on pc and that left stick turning is making it laggy. Like its 5fps. Looks like its worst when turning right, clockwise. I dont know is it meant to be that shitty.
it was before the update so I think its normal.
I think the problem is the guy with the remote. :)
So did this video come from your mobile device?
or
did you download it to a PC from the Phantom with USB or right off the SD card?
:D
I dont have an adapter so i put card into tablet and connect it to pc via usb. Didnt know that its possible right from the phantom
:D
I was trying to make sure that you were not looking at the video that was saved on your mobile.
I hate messing with the tiny card, So I hook up my PC to the Phantom with a USB cable and it comes up as an external drive. Connect to the port on the gimbal and not the phantoms USB port.
Yes, thats a good tip if you dont have memcard reader.
I did ask from dji support about that video. Just love it when everythings gonna be fixed with imu calibration.
Tomorrow will gonna find some better place to fly or crash who knows. Just got a message that i cant fly it here coz its in 5km from airport or just have to call there and ask. I usedgoogle map to check if its in 5km but it showed over 5. :D Didnt go over trees or over 30m distance so i think thats not that bad. 200m and im out of that zone.
Gonna try that imu calibration mby it helps.
Do IMU, then Gimbal.
Standard video quality worse after crash.7
Ok, first flight without beginner mode. Was kinda windy and some birds were interested of my copter. 1 thing that happend and I didnt know what to do. It lost rc signal and started landing it was kinda close to me I guess it was about 15m didnt check that outreally. Height was a little over 70m. Didnt know should I go closer or farther away. It wasnt going to the home point it just started landing. Kinda scary if it should happen at longer distance. Somehow didnt lose fpv that time. I'll try to check that video out for that laggy turning. Tried to turn smoothly. Dont know how it turned outyet
RTFM! :p
It will land in place when within 20m of the RTH location. No need to worry about it doing that at greater distances...it will come home.
Also, try to keep the antenna pointed towards the bird. You may have lost signal because your antenna was pointed directly out. If your going to fly directly overhead (or nearly directly overhead), try moving the antenna to 90° or holding your controller up so it is perpendicular to the bird.
20m ? What ? Mby i take off from a platform and stay in 20m radius.
Anyway havent done imu yet. I guess i have to fridge it :D Gonna do it soon.
Last time and all the time after update it gives me short beep after turning on aircraft. About 1 min or less after that turn on noise. All the lights are OK. Nothing red.
Here is the log file:
[00147980]========== remo-con disconnect. boot(15) ============
[00148130]Packet [C:\P3XW_FW_V99.99.9999.bin] detected, card sn [0x0022a353].
[00148179]Packet upgrade start...
[00148234]Packet checking...
[00148278]Packet vlink 01.05.0040 <-> 01.04.0030.
[00148358]Done.
[00148409]Version checking[1]...
[00148458][01 00][00] v1.2.4935 -> v1.2.4935
[00148504][01 01][00] v1.2.4935 -> v1.2.4935
[00148559][04 00][00] v1.41.0.0 -> v1.44.0.0 need upgrade.
[00148648][03 05][00] v34.2.0.9 -> v34.2.0.9
[00148732][03 06][00] v2.4.15.5 -> v2.4.15.5
[00148817][09 00][00] v0.1.0.12 -> v0.1.0.12
[00148928][12 00][00] v5.9.0.0 -> v5.9.0.0
[00149048][12 01][00] v5.9.0.0 -> v5.9.0.0
[00149153][12 02][00] v5.9.0.0 -> v5.9.0.0
[00149232][12 03][00] v5.9.0.0 -> v5.9.0.0
[00149349][11 00][00] v2.0.0.32 -> v1.8.0.0, firmware v2.0.0.32 not support.
[00149396][11 00][00] v2.0.0.32 -> v1.8.0.0
[00149509][11 01][00] v2.0.0.32 -> v2.0.0.32
[00149559]Done.
[00151605]Waiting for user confirm...
[00161648]Timeout, start upgrade automatically.
[00161739]Firmware upgrading[1]...
[00161862][04 00] Firmware upgrade start...
[00221001][04 00] Firmware upgrade finished successfully.
[00221051]Done.
[00221099]Version checking[2]...
[00221150][01 00][00] v1.2.4935 -> v1.2.4935
[00221194][01 01][00] v1.2.4935 -> v1.2.4935
[00221259][04 00][05] v1.44.0.0 -> v1.44.0.0
[00221355][03 05][00] v34.2.0.9 -> v34.2.0.9
[00221433][03 06][00] v2.4.15.5 -> v2.4.15.5
[00221498][09 00][00] v0.1.0.12 -> v0.1.0.12
[00221606][12 00][00] v5.9.0.0 -> v5.9.0.0
[00221708][12 01][00] v5.9.0.0 -> v5.9.0.0
[00221840][12 02][00] v5.9.0.0 -> v5.9.0.0
[00221952][12 03][00] v5.9.0.0 -> v5.9.0.0
[00222055][11 00][00] v2.0.0.32 -> v1.8.0.0, firmware v2.0.0.32 not support.
[00222102][11 00][00] v2.0.0.32 -> v1.8.0.0
[00222252][11 01][00] v2.0.0.32 -> v2.0.0.32
[00222296]Packet upgrade finish successfully.
Don't actually put in the fridge, Moisture / Condensation.
IMU Calibration
Jerry P
