Problem with tilt control with SJ2D gimbal
Have a P2 with standard 2.2Ghz R/C. (has tilt lever on back) I recently installed the taller wider landing gear on my P2, everything worked great until landing gear install. Now my SJ2D gimbal will react to the tilt lever but it is a very small range of movement of tilt lever. If i start with lever all way to right the gimbal will face down i can move lever a few millimeters to left before the gimbal will move. now if i continue to move lever to left a millimeter or two the gimbal will go to max tilt move it a little more and it goes facing down again. this puts the lever at about the half way point i can proceed to move lever all way to left and nothing.
I have tired to calibrate the R/C via the software with no luck. If i start out all way to right the software shows "1000" and when i move all way to left it does not say "-1000" its like it cycles over and both right max and left max are "1000".
This is kind of hard to explain but i hope i explained it where someone could help me.
Jerry P
