Problem with Stick Calibration
Unboxed my brand new Phantom 2 Vision+, downloaded DJI Phantom 2 Vision Assistant_3.6, hooked up everything to the computer, did all the upgrades, and started basic settings. In the "Command Sticks Calibration", using Mode 2, I show movement on the left stick (T & R) but nothing on the right stick (A & E) when I move it. Tried doing a power cycle & re-calibrate, but same results. Also, under "Stick Monitors" the X1, the indicator is not centered . . . all the way to the right if I click [NORM] & all the way to the left if I click [REV]. The RC is model no. PVT581 (firmware 1.0.2.31). Any suggestions?
Calibrate your remote with the R/C assistant (Different program) and see if this cures the issue.
Not sure from your post if you have already done this? If so, sorry about that!
jeetbuzz360
