I confirm, you can not do the downgrade firmware ... The last reply they gave me is to send the phantom in service but I do not think I will. Meanwhile, I continue to read the post and figure out if there is a solution to this problem.
Hi.
Downgrading the Radio Controller software seem to work for me!
Just flew two full batteries without any glitch!
/Orre
After upgrading to 1.10 I lost reception on my P3P. On my first boot up I lost video and signal after a couple of minutes while adjusting some of the settings. In flight I lost video and radio signal a few times at less than 1000ft away with direct line of sight. I didn't see the broken video image on my iPad like above.
I will try the RC downgrade and see if that helps.
Edit: I just checked the log on Phantom. It says that the current FW is not downgradable.
Hello, that fw is installed in the controller? 1.6?
Exactly the problem is just the ver 1.10.90 it would seem .... I had before Ola vers 1.6 in the controller and also had many ailments with little distance. Now I installed the ver 1.8, and the problem seems to have disappeared. I communicated with DJI but they want it to send the phantom to find the problem.Of course I did not, because I have told them that in my opinion is the fw to give problems.I think it was 1.8 in the RC when I had the disconnects yesterday. I rolled the RC back to 1.6 and haven't flown yet. I rolled the RC back to 1.5.7 but its not compatible with 1.10 on the AC.
I checked the install log on SD card and I had 1.9 before 1.10. I had absolutely no issues with 1.9 and could go about 5000ft or more with slight obstructions.
