Problem with litchi and p3 advanced
Hi, tried out the litchi app which almost ended in disaster. The aircraft drifted away heavily and I had problems returning it to home, but Im not sure this is the apps fault. I first opened the dji app on my ipad, then tapped out and started the litchi app.
Does lightbridge work when using litchi, is lightbridge a communication between aircraft and controller or does it require it of the software (litchi) too?
Also the way you set home location seems to be different on dji go and litchi.
