Pro and wifi
The P3P does not use Wi-Fi. My iPad Mini 2 16GB runs DJI GO with no trouble.
With Lightbridge ( usb cord)I don't need wifi to use the Pro- right? And will a iPad Mini 2 with 16 GB do the job? Thanks!
You are right, the connection between RC and tablet in P3P is thru USB cable. You can use iPad mini 2 and above.
You do not need wifi to fly. If you want the map available where there is no wifi, don't forget to cache the map before you leave wifi availability
Enable the "Cache Maps in the Background" setting in the "General Settings" section of DJI GO and do this:
Jerry P
