Pro 4+ controller battery replacement
Hi I'm urgently looking for a new battery for my Pro 4+ controller, I have been hunting online to no avail. Could someone please let me know where I can find one in the UK.
Many thanks for the help.
I remember a thread a few days ago where a gentleman had bought the wrong controller for his P4. His old rc just needed a battery and didn’t know where to get one. A couple different ones were listed on that thread. Hope you find it.
YouTube has a step by step video on replacing the RC battery on a Pro 4+. They mention the model of battery necessary. It appears that small fingers and miniature tools are helpful along with a good memory to reconnect the kibbles and bits in the right order. Many here can do this with patience. Best of luck.
I replaced mine couple weeks back, I found it on Ebay.
The process for replacing it is fairly simple.
Once you remove 4 screws, underneath pads. (One under each pad)
Grasp the bar(stand) use you thumb underneath antenna and push apart.
Two little catchers on top and two on bottom.
Once open, the battery is under. The main control bord.
After removing the 4 screws that hold that bord down, if your careful you may get away without unplugging the antenna. I did on two different occasions. Once had to. They can be tough.
The clips holding battery in place can be released using flat screw driver.
Hope this helps.
