Hi there,
I currently have a Arris CM2000 powered from my phantom aux power cable.
I have a predator, that currently has the filter board, so it can be powered directly from the battery balance cable.
I'd like to not use this to power the predator as its a pain to plug in every time i change battery.
Can I simply make the aux power cable from the phantom into a Y lead and power both the gimbal and predator? Is ok to not have the filter on that power, or is there an more optimal solution?
I've googled around and not found a definitive answer. thanks.
