Portable hard drive
I happen to be researching this topic right now. I need one that is self powered and is able to accept SD Cards directly.
Reactions: Eagle one 556
What portable hard drive do you guys use in the field?!
Here's mine:
I have been using Western Digital passport Pro Wireless and it is absolutely cool, it's sorts out all of my cards and it totally accessible by every device on my home network it is very cool
We thought long and hard about this important subject.
The WD 4TB MyPassport Wireless Pro seemed ideal. Until you read the countless reviews of it malfunctioning or packing up completely. The concept is ideal for photographers in the field, but the execution was dreadful from such a top company. In the future, WD will hopefully get the problems corrected, but meanwhile that “ideal” option had to be ruled out.
Instead, we use two “normal” portable hard drives - a Seagate and Toshiba, both with good track records for reliability - making two copies of everything. The chances of both failing together are slim. Using two from the same company (and possibly the same manufacturing batch) would increase risk. A laptop provides the intermediary, as well as providing a great viewing screen. All of this data is eventually backed up even more securely back home.
Whether you’re a professional or serious amateur, caution is essential. “Be prepared” not only works, it’s underestimated as a practical key factor for success.
I come from the world of music and protools - and even back in using magnetic tape on 24 track machines - and we ALWAYS backed up 3 times. Triple backups or not at all. I have had, knock wood, only one time where I had to use my third copy in 40 years (magnetic tape - machine ate one, the second had a few rough spots). Hasn't happened on the hard drives but I have had some failed cards. Doesn't matter what u use, just copy copy copy!!!
My solution is similar to that used by Meta4. Use good SD cards, never needed backups.
Because there's no need for anything bigger.
I value my work and don't want to risk sending the results of one flight out on another flight.
I swap cards with each battery change.
Exactly what I have always done and for the exact same reason. To be honest, I dont even understand how anyone can do otherwise.
@Meta4 - whats your guess for how many times you've posted that picture? ;)
I just didn't think 16 is enough if you're getting video. I agree with you about pulling everything off the card as soon as you swap batteries.
What are you going to do when you run out of space. Buy another SD card? I want something that’s organized. Have everything saved in files on a portable hard drive. Why struggle with 50 SD cards?
I have a computer and backup drives at home.
I have 422GB of aerial work backed up just from 2017.
The OP was asking about a portable system.
The pic shows what I take when I go flying for a few hours -.
5 mins of 4K video = 4GB
I don't want to video a whole flight from start to finish.
For my kind of shooting,16GB is much more than I need for one battery.
I agree that having too much footage on a single card is asking for trouble. However, I have been in many situations where I don't have the time to swap cards during every battery change. When the light is changing and the shot is about to go away it's nice to be able to keep the card in place. That being said, there are many situations where time isn't as critical and that practice is totally doable.
We calculated the cost of using many micro SD cards for an extended period of time away overseas and it simply doesn't compete with a reliable portable hard drive for bulk storage.
Like Meta4, we hardly ever record a whole flight - other than counting animals within a long stretch of river - as different from shorter planned sequences. But the amount of data nevertheless adds up when using 4K.
That said, if by "in the field" you mean just being away for a short time period, then micro SD cards are sufficient. And definitely swap them.
