Phantom3 / Kindle
Can anyone say if the Kindle fire HD10 works with DJI go app
some people on here use them loaded them thru backdoor to get them to work
@flpholt -- I'm clueless on how to load via backdoor.. If u know how, kindly assist. Tks much
I think they downloaded app to computer then onto tablet which is side loading it
Thanks.. Will attempt same and keep you posted ..
cool also you can due a search on here for the thread kindle
[emoji106] on it .. #appreciated
Just an update .. I was able to get my Kindle fire HD10 to run the DJI go app.. I downloaded it form www.apkforkindle.com (do a search after) .. Works fine
Reactions: Digdat0
Thanks for the APK install tip. I just got the DJ Go software on my Kindle, looks good, just need to take it out for a test.
Got any updates on if you still use the Kindle and how it's worked (the wifi)? I'm using my iphone 6plus right now and have thought about using a kindle I've had sitting in a box with a cracked screen. I'll replace it and make this a dedicated flying table if so! Thanks
I don't use the kindle anymore. Reason being I can't get the map to work. So in the app it's like I'm flying blind once the phantom goes out of my eyesight. I ASSUME this is because the kindle does not carry a gps pre installed like your iPhone or other tablets. Let me know if this helps.
I didn't wanna spend a lot for the drone screen. So I went out and got this tablet, was reading the reviews on it. Works excellent!! And the processing speed is great.
I would recommend this for flying to anyone. Doesn't glitch or freeze.
Your picture is too small, we cannot read it.
I've tried so many ways.
I can't get the app on my kindle fire
Changed setting to accept apps from unknown sources
Have google play and the kindle isn't listed as compatible devices/
After downloading the apk file it says it has problems parsing the application
If you changed the setting to allow unknown apps you can just go to the dji website and download the app there.
I tried that too
Says it's installed but it doesn't show the kindle as a compatible device
Aerials
