Phantom wont lift off the ground:(
Check your voltage levels in the assistant software, make sure it's reading the correct level of the battery. If the Phantom thinks the battery is below the final warning voltage, it'll let the motors start but won't let you increase the RPM's enough to lift off.
What is the recommended first and second level protection anyway? Mine are set to:
Mine didn't seem to have enough power to take off after I updated. Turned out it was in the wrong mode. I do not remember the mode it was supposed to be in but when I changed it, she worked fine.
tanglefoot
