Hi all I'm new to this forum or any forum relating to the phantom so hello to you all If anyone could help me I'd be so grateful!
I've been using and loving the phantom for some time now, I also have the Zenmuse H3 installed.
However after I upgraded the phantom to firmware 4.0.0 the heli won't seem to lift off the ground. Its as if theres only 50% of vertical throttle? All motors are spinning and the Zenmuse is still working ok it's just as if its in limp mode?
I have done the following several times!
Checked the lid is on correct to correspond with the correct way to put the propellors on. Let me stress that the lid and propellors are put on correct.
Calibrated the Receiver and all is working correct.
Calibrated the IMU
Using latest software 2.18
Test motors - all working and rotating and numbered correct.
Increased the gain to no effect.
Using Quad-rotor X as aircraft type.
Spent hours on google trying to find an answer to this problem most people put the lid on badly but I haven't
Someone On the web says it maybe a faulty transmitter?
What can I do?
It's under a year old so is it still under warranty I think?
I've never crashed the heli and its never had water damage or any type of damage!
It just wont lift off the ground after the firmware update.
Thanks in advance,
Spence
Calibrated the IMU
What can I do?
Thanks in advance,
Spence
