PHANTOM VISION PLUS RETURNS HOME!!!
Discussion in 'Pro/Adv Discussion' started by jasonb777, Sep 19, 2016.
  1. jasonb777
    Jacksonville n.c.
    So long story short, some of you guys that have been members here might of remembered when I crashed in the ocean back in late summer of 2014. Well yesterday my dad was out fishing with my mother here in eastern NC at an island called hammocks beach (bear island) and my mother looked down and saw something white down in the water buried in the sand. It was my old P2V+!!! And it is still intact after 2 years of being in the ocean! We have even had some tropical storms come through since and it is still one piece! Unbelievable... The frame is still one piece and it is white and flexible, just like before, you know when you pinch the landing gear, it flexes! Thought I would share my story, being that Davey Jones has upgraded to somebodies P3 pro and P4 by now. Now, if I could just get this sd card out...:confused:;)
  2. dparkins
    Charlotte, NC
  3. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    How interesting! Can't wait to see the card info!
  4. planedr
    FEMA District VII
    Did you try turning it off and back on again? That might help.
    TnHwyman, arierep60 and yorlik like this.
  5. jasonb777
    Jacksonville n.c.
    I was just being sarcastic...Do you think that it might work after that long? That would be awesome.
  6. LuvMyTJ
    Staff Member
    I would at least try it, as long as the contacts could be cleaned. They are supposed to be pretty much indestructible, not sure about salty water.
    Heres a guy who found one that spent 4 years in the ocean, it worked - Photos Recovered from Camera That Spent Four Years in the Ocean
    Falcon900 likes this.
  7. Ed209
    That's awesome. Clean the card with 99% isopropyl alcohol and let it dry completely. Most pharmacies don't carry 99%, and only have 91%. that just means you have 9% water in there. You can try 91% or order 99% from Amazon. SD cards are sealed pretty well; it's just the contacts that are exposed. Hopefully they didn't corrode away to nothing since they were plugged into the slot.
  8. Trinimon
    Canada
    Wow! That's one heck of a good fortune to stumble onto the bird after two years lost at sea. Hopefully you can get data off the card.
    Edit: Meant years, not weeks.
    #8 Trinimon, Sep 19, 2016
  9. jasonb777
    Jacksonville n.c.
    I just sprayed it with wd40 and I will let it sit for an hour or so. You ca see where the SD card is located in the pic and it covered it a corrosion type material that is hard as rock. I will report back if it is a success.
  10. toegema
    He said it's been two years, not weeks.
  11. Trinimon
    Canada
    Sorry my bad, I meant to say years. Brain fart morning. lol
  12. yorlik
    Reminds me of Gilligan and his 3 hour tour
    Sent from my SM-G900V using Tapatalk
  13. jasonb777
    Jacksonville n.c.
    Well I got the sd card out, and it looks fine; even has the brass colored contacts still, but I cleaned it and it still won't read.:( I just get the time stamp and that's it. I will let it dry for a while and report back. I had contemplated opening the micro sd card up, but it appears to be one piece all the way through.
  14. Ed209
    What time stamp? For each video file? Is the P2V+ the same as the P3 where the file may not have closed properly if power was cut short? If you can see a directory listing of files, that's a good thing. I wouldn't open the SD card up, that will only do more damage. I'm a computer forensics investigator.
  15. fastsmiles
    Fort Worth, Tx
    Unbelievable, I'd hang that catch on the wall!
    Lifted Chevy likes this.
  16. ElGuapo
    Burbank, CA
    you can probably use what is left as an organ donor
  17. finlayson
  18. robinb
    The sd card is probably ok.
    You just need to finalise it by using the software mentioned above or putting in another drone.
  19. Noodle
    Sydney, Australia
    I would treasure this Phantom if I am you.
  20. jasonb777
    Jacksonville n.c.
    I tried to clean some of the build up around the contacts with a pic tool and now the sd card will not even acknowledge when I put it in the computer. I must of have damaged something because before I would get the noise like when you plugged in a usb, but now nothing. As far as what the time stamp or what ever it is called, when the sd card would be acknowledged, it read October 5 2014 2:40pm. The phantom now hangs at my office at work.;)
Similar Threads - PHANTOM VISION PLUS Forum Date
Phantom vision 2 plus Wi-Fi module FPV (First Person View) Dec 22, 2017
Phantom 2 Vision plus batteries dying in seconds.. General Discussion Dec 11, 2017
Dji Phantom 2 vision plus ( P2v+ ) camera/gimbals for sale ( 3 of them ) Classifieds Nov 20, 2017
Phantom 2 Vision Plus for sale *SOLD* Classifieds Oct 26, 2017
Phantom 2 vision plus assistance Phantom 2 Vision + Discussion Sep 5, 2017
