Phantom 4Pro controller help
Hello I asked this question in general discussion but it should be in the help category. I have a Phantom 4 controller with the HDMI module on it. I want to install this on my Phantom 4 Pro controller.
Will the board that is replaced upon installation work on either the Phantom 4 or 4 pro controller? I would need the one coming off the Phantom 4 pro controller to replace the missing one on the Phantom 4 controller.
Couple of pictures,this is one I buy for p4,if one you want to swap looks like that it should work,says up top for pro+ or p4
Thanks for the pictures. I know the module will work. What I am unsure of is the board that it replaces. I bought the Phantom 4 with the module. If I swap it to my 4 pro controller then the board it replaces I would need to put on the phantom 4 controller for it to work. I just need to know if that board is the same on the Phantom 4 and Pro controllers.
Apparently the ribbon cables plug up the same I just read,I don't see why not,,a dji mindy post said they change firmware while back so they can be compatible,
Must be OK to use ,no one else say it wrong or don't work
I knew the HDMI module would work. I was unsure taking the old board out of the pro controller and installing it in the standard one. I did the swap tonight with no issues.
robvalduga
