- Joined
- Aug 14, 2016
- Messages
- 1,075
- Reaction score
- 169
- Age
- 39
Im sure most use IR temp guns improperly and get incorrect readings. Everything emits IR and that's what the gun sees. But, not every material at the same temperature emits the same amount of IR energy. Most cheap IR thermometers have a fixed emissivity value of about .95. Better units have selectable emissivity values for more accurate temps. Wood, iron, blacktop, white paper, etc emit different IR at same temp. There are charts for this. If you want the most accurate temps with the cheaper units...have a flat black spot on motor to read temp. Also the FOV of the unit makes a big difference . Even cheap units may have a laser on them. You may think the laser dot is the only thing you are reading but you would be wrong. Just try to take a temp of a chrome bumper or mirror reflecting the sky and you will get some crazy readings. I use an expensive Fluke for my work. I can't get by with the $30 IR thermometers that have flooded ebay. I have to measure copper lines at times. A new shiny piece and an older oxidized piece will give me different readings at the same temp. As usual....know your equipment and how to use it.[/QUOTE]I'm UOTE="KingDad1985, post: 908773, member: 69792"]What is the maximum temp the motor can get before damage occurs? I have a IR temp gun and I want to make sure my motors are safe. Thank you!
Not sure how you measure temps but even after an easy flight my motor temps are much higher than 72-78 degrees F. I can tell that just by touching themI;ve never recorded a motor temp.of more than 79 degrees F. after 12-16 minute flights.
Averages- 72-78 degrees.
Highest reading from back left motor, which is the prop. that I stuck in the sand after a rollover.
With mine sitting outside waiting for me to take off and an ambient temp of 90 degrees, the motor temp is also 90 degrees (assuming it's been sitting in the shade) before I even start the motors. After flying, they couldn't be less than the ambient temp. For yours to always be 72-78 degrees even after flying, you must always be flying in pretty cool ambient temps. If you're flying on a 90 degree day, they can't possibly be cooler than the air around them (90 degrees).I;ve never recorded a motor temp.of more than 79 degrees F. after 12-16 minute flights.
THAT is what's important. Even if your temp readings are incorrect, as long as you're getting consistent results every time and there are no flames, smoke, mushroom clouds, etc., then you have a good baseline to compare to....I know these temps. are always the same range....
One off question. I haven't had any issue with temps. I was just curiousOkay. New to this and why is this a consideration? Didn't DJI design these things to fly multiple times, and to be pretty much maintenance free? Is motor temp an issue or just a one off question. This is the first time I have ever seen this come up.
