Phantom 4 Pro
Arizona
Phantom 4 Pro drone V1
Controller
Battery charging station
4 DJI brand batteries with between 25 and 30 charges each
2 sets of standard props
1 set of low noise props
Polar Pro ND filter set (4, 8, 16 Polarizors and 8, 16, 32 ND filters)
1 reflective antennae range booster (forget what brand)
1 USB cable for controller to tablet
1 Case Club hard case
Drone flies great and is in good condition.* Never crashed and always hand caught. Controller and drone firmware are up-to-date including an IMU calibration.
I’m selling it because I prefer the Mavic series and the Phantom 4 Pro would continue to just sit on my shelf.
*Except it needs a new GPS module (or it’s a loose connection) which can be found online for around $65.00. Can be installed by DJI, Drone Nerds, or yourself if skilled enough. There’s a youtube tutorial available. Drone can still be flown with confidence if you are capable of flying in Atti-like mode. See this thread: Phantom 4 Mystery Atti mode
Asking $1000.00 cash Tucson/Phoenix area
Interested. Batteries question.
Looks like 2 high capacity (P4P) and 2 standard (P4) batteries? And as you said all at 30 cycles or less and by DJI? No swelling and charge correctly?
Thank you much.
Thank you much.
Just checked, you're right, two of each. Right, no swelling. I can get the exact # of charges for each if you want.
Thanks for checking. Cycles would be helpful when you get a chance, just in case. Been in the machines before so considering. Battery value important 👍
Reactions: gringorio
Ok, so here are the battery charges
Phantom 4 batteries:
Battery 1 - 26 charges
Battery 2 - 26 charges
Phantom 4 high capacity batteries:
Battery 3 - 23 charges
Battery 4 - 13 charges
The photos are in order of battery 1, 2, 3, 4 ...
Reactions: Capt KO
waterwin
