Phantom 4 pro battery signal error?
Hi all.
As stated before have been flying my phantom 4 pro since Dec 2016 without any major problems.
Drone itself has recently developed a crack in the bottom shell which i am in the process of fixing.
Now over the last few days my drone is showing and intermittent battery signal error with all 4 of my battery's.
I can turn the drone on and it displays the error then i can move the battery slightly and the error will disappear then when i take off the error appears and disappears sporadically and battery percentage is only updated every time battery signal reappears. On my last flight the drone actually tried to auto land itself which i overruled and landed myself as it was about to land into the sea.
What could be causing this problem? faulty wiring inside drone? i have looked at contacts on the battery's and drone and they look ok.
I am using the following.
DJI Go 4 app 4.0.7
Remote 01.04.00.00
Aircraft 0.0.1.4
APP Database 00.00.01.04
Thanks.
John.
Hi this is a photo of the inside connector on the drone.
пишет: ошибка батареи, нет сигнала с батареей. Кто нибудь подскажет что делать? У меня есть 2 аккумулятора и на обеих тоже самое.
