Phantom 4 lost power mid flight
I was flying my phantom 4 yesterday for 2 minutes over the lake in -30 degrees Celsius and it suddenly died and crashed into the ice. I went out and got it and put it in rice it works now but one of the arms is broken and no power is going through the wires. Landing gear is cracked too. Was wondering if it was too cold for the drone as battery had %60 charge
If you are looking for a diagnosis of what happened then you will need to download and post the aircraft DAT file:
How to retrieve a V3 .DAT File from the AC
If you find it difficult to upload the .dat file from the aircraft, you can upload the .txt log from your device to the following link, the .dat file is more detailed, but possibly the other one would prove easier, and a starting point. Either way, be sure and post a link back here to your uploaded file, whichever one you choose, for others to review.
DJI Flight Log Viewer
Easier yes, but likely not much use since the txt log does not contain the detailed temperature readings or motor parameters.
hcashmore11
