- Joined
- Mar 29, 2016
- Messages
- 1,727
- Reaction score
- 504
- Age
- 62
Just saying to try and avoid time where holes have not light on them at all if you can. You'll be going at all angles as far as sun goes too. This was great practice for sure! And it def takes practice especially if your gonna fly it manual which I think you'll love once you get the hang of greasing in the yaw!Hey KevMo - thanks for the feedback. I agree/disagree with the time of day but I do agree the lighting was poor for the ones I filmed. The sun was up and the light on other areas of the course was soft and absolutely perfect. My trip out there today was 100% just to practice. My plan is to go back same time in the AM and film the parts of the course where the lighting is perfect, and the darker areas of the course probably late in the afternoon or early evening.
Are there specific settings you could recommend I read up on? Thinking back to these two holes I don't recall any major elevation changes. It was fairly flat.
Thanks again!
I would recommend YouTubing Litchi and go through several clips of tutorials on it. Some guys use Google Maps to program their flight and then open that up in Litchi somehow. I always programmed mine directly on my Air 2 pad in Lithci itself. I'm guessing that you have a camera command problem in your programmed flight. And yes, your hole that you showed was pretty flat so Object Avoidance wouldn't have been causing your jerk down the fairway because you were up in altitude enough. I'm just not sure man.
