Phantom 4 Pro v01.06.0910 - Inconsistent Firmware Found
Arizona
Has anyone else seen version 01.06.0910 firmware?
I received a new Phantom 4 Pro v1 (Obsidian) aircraft back from DJI repair on Friday, with firmware v01.06.0910. I am not trying to upgrade, nor did I perform an upgrade - it came from DJI with this firmware version.
When starting up for a new flight, I get an "Inconsistent Firmware Found" dialog in DJI GO4, so I "slide to Update." That appears to be successful, but I continually get the same message after each startup.
I have gone through the process at least three times on all eight of my batteries (more than 10 times on one battery), trying different sequences of powering on and off the aircraft, controller, and iPad. All with the same (non-) result.
I have also connected the aircraft to DJI Assistant 2 for Phantom, and get the same behavior. There is not an option to downgrade to a different firmware version.
Reactions: Davyboy433
Odd. I’ll watch this one and possibly learn something.
I do have an older mavic pro with an odd firmware number that I have not seen elsewhere.
