..... teenagers. but hey better than me having to do it.......
haha...i wish i had a teenage slave!
the circular one fits perfectly.....although I could recommend to get rid of the little keyhole thing, so the bottom turns out better since it will be printing the plastic circularly without interruption.I also posted to thingiverse Phantom 4 Battery Charger Covers by pprzen01
the rectangular one is too big...I also posted to thingiverse Phantom 4 Battery Charger Covers by pprzen01
Exactly. Anyway to fix that? Thank you so muchI just printed them in glow in the dark ABS , the rectangular cover is just a tad longer than it needs to be, the width is good. is that what you mean? or did the width not work?
no problem....i also tried scaling x-axis down 2%, but still doesn't fit.....it's probably the way the dremel software scales things......I'll be patiently awaiting the updated file =)Yep , btw thank you for testing for meI scaled the x axis down by 2 % and it worked great, I'll fix and shoot the file to you when I get home
Still doesn't work for mesorry about the delay.... this one worked great for me
Still doesn't work for me![]()
is it possible to get 3 black and 1 white?I just released a new product -- a battery charger cap to cover the end of the battery charger cable to protect it from damage and/or to keep it from making contact with liquid or metallic objects while plugged in and not in use. The side of the cap contains a rectangular slot (2mm x 8mm) that can be used to attach the cap to the cable with a string..
Like my other products, all I'm asking is for you to cover the cost of shipping. However, you're certainly welcome to make a donation if you would like to support my mission to create more unique Phantom products
You can find more details and/or order a battery cover at:
https://www.phantomhelp.com/P4BatteryChargerCap
Yes. Order 4 and then PM me your email address afterwards.is it possible to get 3 black and 1 white?
thanks, I didn't realize I posted this question once in each thread hahaYes. Order 4 and then PM me your email address afterwards.
