Phantom 4 Batteries...
I've got an issue with my "3-battery charger" or rather the batteries. When I put them on the charger, they light up with the flashing green indicator lights but within a minute or two the lights go out and it appears they are no longer charging. The blue lights in the charger remains lit. When I remove the batteries and check them for charge (by pressing the button on the battery packs), it is indicated they have taken on no extra charge.
Just a thought...have you tried putting only one battery on the charger? There is a chance it can no longer output it's original amount of charging current.
I have had this same issue with my Phantom 3 Pro (3 battery charger) sometimes if all 3 batteries are installed before plugging in the power supply, it will stop changing after 30 seconds or so. But if I plug in the power supply first and add the batteries One at a time it proceeds to charge them all fine. HTHs
I have charged it on the wall charger and it works.... the multi charger is failing with eiter one or more batteries
hcashmore11
