Result: Success.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
========== 2015.09.21 16:34:55 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.09.21 16:35:48 =====================
Result: Abort.
Result: Abort.
========== 2015.09.24 18:52:30 =====================
Result: Abort.
Result: Abort.
Result: Abort.
========== 2015.10.11 16:31:14 =====================
Result: Abort.
========== 2015.10.11 16:35:01 =====================
========== 2015.10.11 16:36:32 =====================
========== 2015.10.11 16:38:01 =====================
========== 2014.01.01 00:00:11 remo-con disconnect======
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2015.10.11 16:42:40 =====================
Result: Failed.
========== 2014.01.01 00:00:13 remo-con disconnect======
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:14 remo-con disconnect======
========== 2015.11.11 12:47:31 =====================
Result: Failed.
Result: Failed.
Result: Failed.
========== 2015.11.11 14:48:11 =====================
Result: Failed.
Result: Abort.
========== 2015.11.19 11:30:14 =====================
Packet: P3X_FW_V01.03.0020.bin
Upgrading ...
Upgrading ...
Result: Success.
Result: Abort.
========== 2014.01.01 00:00:16 remo-con disconnect======
Upgrading ...
Result: Success.
Packet: P3X_FW_V01.08.0080.bin
Upgrading ...
Result: Success.
========== 2016.04.21 15:29:47 =====================
Result: Abort.
========== 2016.04.27 10:08:48 =====================
Result: Abort.
========== 2016.04.27 10:10:31 =====================
Result: Abort.
========== 2016.04.27 10:11:36 =====================
Result: Abort.
========== 2016.04.27 10:13:46 =====================
Result: Abort.
========== 2016.04.27 10:25:22 =====================
Result: Abort.
========== 2016.04.27 10:33:20 =====================
Result: Abort.
========== 2016.04.27 10:39:52 =====================
Result: Abort.
========== 2016.04.27 10:42:34 =====================
Result: Abort.
========== 2016.04.27 10:43:36 =====================
Result: Abort.
========== 2016.04.27 10:45:43 =====================
Result: Abort.
========== 2016.04.27 10:50:34 =====================
Result: Abort.
Sent from my iPhone using
PhantomPilots
