Phantom 3 Pro problem no image transmission signal
Helooo
I hav probelm with may Phantom 3 Pro. I used phantom i crashit and i change the ribbon cable, afther that i have problem i dont have picure from camera the gimbal is working wery good and i getting mesage no image transmission signal.. Please can you help me.. Thenxx
Have you updated firmware? My p3s has the same problem but I never crashed or damaged the drone in anyway. Just updated firmware to 1.9.2 and now it’s screwed
I didnt do update fimwere. You will se on picture in wich firmware is
Helooo
It can be common problem after a repair Nurkic.
I don't know where you bought your ribbon cable from but there are some cables which are not so good.
I would also re-check that the ribbon cable connectors are also well-fitted, if I was you.
Here is one thread about ribbon cables Places to buy Pro/Advance camera ribbon cable part 49. but if you do a search (the magnifying glass, top right) with words, 'ribbon cable'. you may find more information which may help you.
Good luck!
Good luck!
I bought ribbon cable from dji store and i check all connectors are good.Hmmm but when i disconect gimbal from phantom i also have the same mesage no transsmition image signal.
The "no FPV" subject comes up every week, and each time everyone is acting like it's a first..
Base question is - does the problem occur before or after Ambarella chip. In other words, are images and videos saved correctly on SD-card.
The next step after you know that would be to search the forum.
hcashmore11
