Phantom 3 Pro Camera Issue
Greetings All,
Yesterday I unpacked my Phantom 3 Pro, I bought from DJI direct (refurbished) last summer as a back up to my primary P3P. I have been using DJI quads since the P1 came out and have several and very familiar with the set up and operations of these drones. Anyways, the unused P3P setup perfectly and performed as expected except when I began to dial up different camera settings; ISO, shutter speeds, etc....when the horizon began to fill in with slanted black and white near vertical bars as I scaled from lower to higher shutter settings as well as when I moved up from 200 to 800 ISO? The darker I left the settings the screen picture became clear but as I went back to adjusting the settings the above horizon black and white slanted bars appeared. Clearly I'm missing something as everything else works perfectly. If anyone has some idea here I would appreciate it.
Diagonal zebra stripes in bright parts of the scene?
That's the overexposure warning.
You can enable/disable it in your camera settings
Here's the setting in DJI Go 4 .. it should be similar in Go3 on your P3
Thanks Guys,
I knew it was a simple solution and glad to have the forum resource to remedy it quick!
CL
