Phantom 3 EU output power limit
wow - if that info from pea was true it might open up possibilities. I could see if the CE and non CE version have different values??
"I have found a way to increase the power. Plug your P3 to a computer via the USB connector, wait for it to be recognized. You will see a new device in the windows device manager "generic usb communications port". Right click that, select "properties" and tick the box "allow console acess via localhost". Then use putty or a similar terminal emulator and connect via RSH to "127.0.0.1" using username "root". Password is "0090034". You are then logged in the bird.
Change directory to /etc/config/wireless, and edit the file "lbridge.cfg" using vi. Look for the setting "txpower". Depending on if your model is CE or FCC, it will be either 5 or 9. You can change this to a maximum of 15. Not sure how that will affect temperatures of the wireless unit.. but I've tried it with a value of 12 and got a huge increase in range. Edit the setting, save the file, then power-cycle the unit.
Let me know how far you guys can get with this."
Could me pls help me how to that on a Mac ?
Also the height limit.
Many thanks.
The quoted post is fake and from a recent troll.
I got another confirmation from DJI this is set in a factory:
DJI Forum|Phantom 3 mode: FCC (USA) v.s. CE (Europe)
I have asked about changing int in their service, and i got negative answer.
I also asked what should I do, get a new radio or new parts from a drone. I got answer it is both in radio and a bird.
"This also refers to both the radio receiver ,so it does not work to change the remote controller."
Thats what I got.
Windows10, firmware P3X_FW_V01.07.0060. Computer connection with bird , see attached file. Why? Please help!
Thats what RC send to drone....commands from RC. In this case you don`t need to know root password because it no need to log in. I think you use wrong usb on bird....try this on ligtbr.unit...it ask you for username and password....and I think the password 0090034 is wrong, but You can try....meaby you get lucky!
Yea. Old news. ;) But it was changed to 0090210.
Hello, some news ? I have the feeling that this history of debriding to FCC is only ********. Someone succeeded to connect ?
Thank you !
