Phantom 3 cases
Hello I'm new to this app and looking for a case for my phantom 3 standard I'm looking at all the ones online and they all say optimized to fit phantom 3 adv/pro will they still fit my standard?
The P3S will not fit in all P3A/P3P cases since the remote controller is not the same size. I have a list of cases that are compatible with the P3S here.
There are good soft & hard backpacks too. It all depends on what your primary need is. I have both a hard travel case and a DJI soft backpack. I use the hard case only for air travel as it is heavy, it weighs about 17lbs itself. I use the backpack for most everything else.
Check out the Koozam Case. It really fits well all 3 of the Phantom 3 models including the Standard. What I like I can keep the props on and it has lots if room for extra batteries and accessories. Not cheap at $179.95, but definitely a nice sturdy case.
I bought a backpack case on amazon for 49.95. All it said was it was for a phantom 3. It fit fine. The inside is foam, so you can alter it if you have prop guards or some other option. I have them, but they have to be removable, and your props have to come off. That's no big deal though. I think its made by Cheerwing. I'm happy with it.
Get something like this. This is made for phantoms
Or you can get a copy version, a bit cheaper.
Reactions: Mudcat
I want a case that can fit my p3s without taking off my props. Any ebay links would be appreciated. Thanks
ctlfreak
