Phantom 3 4K ARGtek
Some have with the argtek setup,,better than stock,,you'll just have to test and try different things to see what gets you the best results,,maybe put a wind surfer on that 5.8 antenna,,tests tells the tale,,environmental conditions can effect things day to day,,location also,,just food for thought,,,
Got ya.. but what i wanted to kno was that my wiring being wrong played a part in it?
This is my drone
Ok I looked at you earlier pic,,you might have to route the white wire under the switch to get the slack you need,,yes p34k I'm with you,,
The first pic you posted its under the switch,,it should reach that way,,the second pic. Its not routed that way
Ah your an old pro at it now,,the best thing is now you can switch antennas without opening it up again,,
sansuciboy1
