Phantom 2 Vision: Broken Camera Mount
My Phantom 2 Vision just arrived and it appears to have a broken camera mount; the camera is dangling loosely from one side (see image). Can this be easily repaired or should I just exchange for a new one? Thanks.
It popped off the guide pin!
It is an easy fix:
1st:
Unhook camera from ( anti jello mounts ) the 4 rubber balls
2nd:
Unhook BOTH WIRES ( plug on back of camera, and servo plug )
( take needle, remove small rubber plug, and tiny Phillips screw, on
Camera RIGHT side mount, so servo will come out ) little white plug ( screw under plug )
3rd:
Locate 4 Phillips screws at top of mount ( remove them & cover )
4th:
Carefully remove servo ( camera should come loose from mount )
5th:
Pop mount back on PIN SIDE ( first )
6th:
Replace servo ( lining it up with other side of mount )
Replace screw and small rubber plug!
7th:
Replace cover plate and 4 screws
8th:
Plug BOTH PLUGS BACK IN
9th:
Clip servo plug onto clips top of cover plate
10th:
Reinstall mount to 4 anti jello balls!
Go fly!
Thanks, Jerry. Turns out the black guide pin was broken off and inside the camera mount, so I disassembled everything, retrieved the pin, super-glued it back on, reassembled everything, and I'm good to go. Off to the park to fly!
robvalduga
