phantom 2, help please
Hello, I have a phantom 2 drone ,with small problems, had a minor accident.
don't burn that lights 3 arms, would be the problem?
and how can I check if the motor is not burned?
thank you.
thank you.
I do not understand. Do you mean the LEDs on three arms work but not on one arm? It is not likely there is any damage to the motor but you may have damaged the ESC module that controls if that motor does not turn on with the restwhen powered up.
3 arms no , 1 yes
Here is what the inside of the P2 looks like.
By your brief answer i take it that only one motor and LEDs works.and the other three don't. Would that be correct? In any case you're going to have to open up the unit and check it out. What did you crash into? With three arms not working sounds like you P2 crashed in water.
How do I put the wires, black, red, yellow to the engine?
3 engines not working and leds not work.
sorry because not write too well but I use translator
If you key on the photo I sent you it will enlarge so you can where the wires go. The motors with either a black dot or black shaft are the CCW motors. I think you wasting your money if you are replacing the motors. You did not answer how you crash the P2 and into what but i suspect it was in water.
With the little information you have supplied it is impossible to help you.
crash in the woods , I have not found only after an hour , and engines not or stopped and or burnt out
Motor are very rugged But the ESC modules are not and they will burnout before the motors. So you will need 3 new boards but to be on the safe side order 4 boards
In which country do you live?
I'm from romania . you ??
and engines not change them ? how can I check , what voltage?
Usachman
