Hi, I am Craig who sold Green_Phantom a DJ6 unit that did not work as expected. We have since replaced it with another that is working fine and I think that it was my fault by giving incorrect binding instructions that cause Green_Phantom to have an issue.
Here is what I posted on another thread about the same subject. I hope cross posting this once is ok with the admins
I do want to address the binding process. I gave incorrect instructions in the past and I wish to correct that. There is no need to either press a button while powering on or hold down any sticks. The process is so very simple and I promise this works as I have tested it on 25 DJ6 units and it works without fail. I used 5 different Phantom V1.x models with the Part 31 Receiver that I also sale as a kit with the dj6.
ASSUMING YOU HAVE REMOVED YOUR PROPELLERS!!
Here is the correct method to bind, no matter what version of firmware.
1. Plug in battery with battery out of quad, the light wiill come on solid red on the receiver in the battery compartment.
2. Turn on DJ6. The led in the battery compartment will begin to blink green.
3. Hold down (or up really) press the button next to the led on the receiver until the light blinks red once or twice, 2 or 3 seconds, then let go.
YOU ARE NOW BOUND TO THE QUADCOPTER. CSC THE STICKS AND THE MOTORS WILL START.. NO PROPS, RIGHT?
Of course it is a good idea to check your software settings after doing the firmware upgrade, IMU, failsafe, Return to Home and any limits might need to be reset.
