Phantom 2 can bus pin out
Hi folks. I'm trying to eliminate one of the can bus connectors so I can mount the ground station xmit inside the phantom a little more easily. Does anyone know the pin out for the connector so I can wire it directly to the mail board.
Thank you in advance.
You don't want a $70 CAN Hub that's nothing but 5 connectors wired together in parallel? ;)
Be careful with the wire colors inside the CAN cable, as it doesn't match up to anything standard at all. Ohm yours out to make sure what is connected to where before rewiring and powering things back up if you're going to hack any of them up.
Red = GND (brilliant)
Orange = 5.5v
Yellow = CANH
Brown = CANL
MALE CAN CONNECTOR
FEMALE CAN CONNECTOR
NOTE: The CAN connector inside the Phantom 2 has a different pinout than the external CAN connector.
Welcome.
dlr11164
