I took a break from working on this during the week, got new truck and played in the snow.
I have the "broken" camera hooked up to a "good" p3a to workaround the compass issues. The camera is at 1.01.00009 and wont take any different/new firmware, shows camera error. I tried the service bin file (big thank you to Apilot101 as well) and i got it to actually try and run that file, the camrea LED flashes green/red when i did it (it wouldnt do this for anything else). After a few minutes, it showed solid red LED showing failure. It renamed the firmware file "MVOM0Fw.bin" to "MVOM0Fw_damaged.bin" and left this detail in the P3X_FW_LOG_AB.txt log file:
[00010847][17 01] Firmware upgrading start...
[00010790][17 01] Firmware upgrading start...
[00053300][17 01] Firmware upgrade finish failed (step = 2, err = 0x00).
Next step is to downgrade to DJI Pilot 1.2 and see what the camera does. I may also rollback RC to 1.4 or 1.3 to see if it helps per some advice ive received. I'm also going to try putting all the files from the internal SD card back on it, including the file SYS.DJI to see if it helps and re-run the MV service bin file through camera.
I don't have a "good" camera to try on the broken aircraft, but i did try to remove the compass from main board and turning on, it still showed compass error. I tried another / good compass and same thing. I;m focusing on fixing this camera for now, gonna look at the aircraft later in the week. I wont lie, im not entirely optimistic, so I'm not investing alot of time .. and its been snowing and I have a new truck to play with
Will keep ya guys posted.
