PC Ground station for Vision2+
We know that the Ground Station app is very basic. You can set waypoints and height, but that's it.
What I need are a few more basic functions:
  • 1) To be able to save the path so it can be repeated
    2) To set yaw and camera angles
    3) to take photos.
Atleast number 1 is needed.
a) Can "PC Ground station" be used for Vison2+?
b) Does it exist any other software program that has the functions and work for Vision2+?
You need to install the 2.4 or 900mhz data link in order to use the PC Ground Station. People have had issues with the 2.4 system on the V2P since it interferes with the 2.4 fpv signal. There have been successes with using the 900mhz system. I have one coming. I found a good deal on one. They are over twice the cost of the 2.4 system and you cannot use the bluetooth/iPad ground station but it does have much more range then the 2.4. You will also need the Can Module in order to connect the data link to the flight controller. Those are only $12-$16 though. Installation is pretty straightforward. Hope that helps.
Nip
