PC doesn't recognize when Phantom is plugged in
Mako79 said:
Judging from the link below, If it uses the same pin connectors as the GPS plug, then unplug it and clean the connectors.
You did mention of a shell swap. Also check if you installed in backwards (is it possible?).
http://www.justhobbies.net.au/djip2-s04 ... -usb-cable
probably gonna drop by the store and let them check. Hoping that it isn't the USB interface pin connector that went bad.
Because after I crashed the drone into the tree the other time, I went back home to plug it in and the phantom vision assistant could still recognize it.
It is just after i changed the shell and this happened. weird.
I had the same issue.
The wires going to the USB connector at the bottom of the remote are extremely fragile.
One of them had broken.
A quick solder job fixed it.
I had done several mods to the remote; I suspect opening / closing it so many times caused it.
Thanks for your input. Gonna check that particular area
Latekale
