It's very hard to guess.Please what could cause p4p not to stable on air while hovering? ..it just keeps moving slowly without controlling it
Thanks a lotAny particular direction,,got GPS lock when this is going on,,as above do calibrations and if not correct itself upload some data,,should hold position even if props out of balance
Aw, come on. Guessing is what we do here ?. At least until the logs get posted, and the truth is revealed!You can't expect any useful advice until you upload your flight.log onto what Meta4 have said.
Otherwise it's all a guessing.
Both the aircraft and the batteries were bought last year NovemberConsidering you might have tried all of the above, the only other thing i can think of is that your Battery might be compromised and the intelligent flight might not be working 100%.
How old is the battery ? Have you updated them ?
I have only had this hover drift once and it was a bad battery that would not let it hover niclely.
Still no answer without the logs. The answer and solution is in there. Please try. We are also interested in the Why. It’s how we learn, from others mistakes or successes. ✌Both the aircraft and the batteries were bought last year November
It sounds like the OP really isn't interested to find out.Sounds like you might be in ATTI mode... Check switch on front left of controller. Make sure it's on P
