P4 help with Gimbal disconnected and other issues.
I received a P4 from a relative who had it a while then encountered problems and let it sit without getting it fixed. So I have it now and been poking around in the forums on the issues but seems like this unit has a few things going on and I'm not sure what the best step forward is. So here's what I know:
  • Powers up with Gimbal disconnected always
  • Have Air Encoder Error (0x2800020)
  • Camera image works for a few minutes and then get "No image transmission signal"
  • SD Card is present but when trying to Format it says "No SD Card" - Have tried multiple SD cards, formatting in Windows. They work fine and also work in a P3 I have.
  • Firmware is 2.00.0106 - Tried updating multiple ways w/o success and it is not my understanding that you can't update firmware with gimbal disconnected error.
Any ideas on first place to start with this thing?
I guess it can help.
are you sure the controller is communicating with your tablet or ph. I have found that the USB module under the controller is not the best of quality and they wear out and have to be replaced, I`ve had to replace 3 , 2 on the P3P`s and 1 on the Inspire and it caused several issue`s including no video transmission and not connected when flying, when you plug in you usb cable ,it should be nice and snug, mine was lose and I could wiggle it around and got all kinds of weird message`s, just a thought
Reactions: Florida Phantom
Dragonslair
