P4 battery loose in shell
I just got my new P4 today and also bought 2 spare batteries.
The original battery has much more play while sliding the battery in and sometimes the bottom clip doesn't even lock when pushing it to the end. Even when manipulating the battery a bit to get the bottom clip to lock you can still move that side of the battery up and down quite a bit. The other 2 spare batteries have almost no movement. Is this normal for some batteries to have this movement? I'm just stressed that this will cause wear and even worse cause the batt to disconnect. Thanks for any advise
few people on here have had that problem don't use that battery return it not worth it falling out during flight
Reactions: flpholt
Hi Jase, any important info about the battery issue? How everything working with that, did u change the battery or u kept it
I just returned them and the shop replaced them, the new ones were fine :) Not worth risking a crash over some faulty clips
Falcoray
