P3S RTH close to 50 m hight
Hi,
My P3S do RTH close to 50 meters of altitude, I see It begin when I move left stick to left or right. Is it normal? What should I do?
Hi,
That depends. If it was 50 meters (164 feet) straight above you, it's possible to lose signal. For best performance, you want to keep the AC out in front of you.
If it was out in front, and then you turn and lose signal, you could have a loose antenna connection inside the AC.
Hello
The premature RTH was caused by the RF module located inside the drone. The RF module has a series of welded contacts on both sides, one of the sides was unsoldered. Both sides were welded and the problem was eliminated.
Thank you all for your input
Daniel John
