P3s issues
Hello, am a newby to this forum.
Due to lack of funds, ie purchasing brand new, i bought a damaged P3S on ebay. Please dont judge.
The drone appears to have sustained a major blow to the gimbal. The camera appears fine,the flex cable appears fine, however the aluminium base plate has a massive crack and some of the gimbal arms are slightly bent. I have managed to, bend back the arms and are now true and weld the base plate. When all is connected the gimbal does the chicken dance, and have since adjusted the moto to sensor as per the many helpful guises on youtube.
Problem here is that the gimbal still does the chicken dance and since purchase i havnt been able to connect the phantom to the Dji go app. Always says weak connection. The gimbal led fires up in green but after a while goes red.
I have tried to update/downgrade the firmware but have not been successfull. Led on the gimbal board fkashes green red but after 10 mins it goes solid red. I have also tried to re bind the phantom as per the manual, but also cant do that. I note when i turn the phantom and rc on the small binding button on the phantom, is solid green.
Initially i hadnt been able to activate/switch the motors on, would light up and stay affixed to rapid red yellow green. Since then, i have disconnected the gimbal, but not the antenna cables, just the 8 wire cable. I can now turn on the phantom and fly it fine.
As the functionality of the phantom is considerably dicreased without a gimbal, i wish to get the gimbal and phantom to its former glory. Has anyone encountered a similar problem? Does anyone have any suggestions as to what might be the problem in the gimbal?
Regards
Hay man thabks for the quick response.
It eventually stops, however the gimbal motors get really hot. Too hot for comfort.
Check the white cables connecting the gimbal to the craft maybe. Sall I've got. Maybe someone else can speak to the lights.
Thanks again nightwolf. The cables appear to be ok. I might rip it off and connect my multi meter and test them for continuity.
Without the drone flying.....the "gimbal motors" will get very hot with No air flow around them......when we have to do some " No spinning " of the props tests..we always face a small fan on the gimbal assembly to further prevent over heating damage !
hi guys need your assistance ,i purchase a crash PS3 on eBay, didn't had much damages ,just the black antenna cable was ripped from the gimbal board ,But the drone worked great.However i purchase a gimbal board on ebay and install it .After powering up the drone hell broke loose ,the gimbal start moving uncontrollable with motors getting very hot .I replace the board with my broken board that previously worked ,but the gimbal still moving uncontrollable. I checked the gimbal cable ,wifi cables all seems to be good. Besides that there is no video connection with the app ,connection between drone and remote inconsistent .
any suggestions will help.
juffe
