P3S Controller Mystery Hole
South Burlington, Vermont, USA
Does anyone know what this hole with the "x" beside it is on the bottom of my P3S controller is for?
It has no function. This controller design was taken from the P2. When using that Phantom, you can use that hole to add a lever that tilts the gimbal.
The remote controller was a little bit different. There are two holes -- one for the tilt and the other to select FCC/CE.
Reactions: p3s_noob
In the P3S remote controller? If so, there is nothing beneath that hole.
If you have the special tool that fits in there just right, you can access the auxiliary flux capacitor. You then can, via DJI Go, view the past or future whatever way you want to fly. ;) .
I believe I made a flux capacitor.
Repaired the power supply module in an LED stage lighting fixture and had too much flux between AC supply connection I had recovered. It arced.
YvetteMarl
