I've been getting 2.5 more minutes per flight. Using same battery for these testsMinutes? Yes dream... This new motors at best can give you 30 seconds more, I doubt is much more than that...
Even them any flightime improvement is very welcome.
take a pic of the box and post it. kind of over blown kind of not.. potentially could save you a headache down the road but then again the newer engines havent been out long enough so for all anyone knows there could be an issue with them as wellI just purchased a DJI Phantom 3 ADV in Canada, after reading this I am not sure if I should keep the unit. I am not sure what engines are in it? If I open the box apparently the unit is mine, as for now I can return(I still haven't opened the box). I asked the seller in this case Staples, if I could look then return, they said No. Is it worth buying from a different retailer to confirm new engines? or is this over blown concern?
there you go. thats how you tellIf the box says W322A on the side also. It's the newer model. I bought mine of amazon.CA over a month ago and it was the newer one.
Mine is w322a. Phantom advanced,new shell and motor type.The sticker to the right or left of that and then just to the right odbDJI it will say w332 or w332a
Bad idea showing your serial #sHere is what is on my box.
This is not true in my case. I have a P3P that does not have any mention of W322A on the box and it has the new motors.If the box says W322A on the side also. It's the newer model. I bought mine of amazon.CA over a month ago and it was the newer one.
Way overblown and threads like this are unnecessarily scaring owners.I just purchased a DJI Phantom 3 ADV in Canada, after reading this I am not sure if I should keep the unit. I am not sure what engines are in it? If I open the box apparently the unit is mine, as for now I can return(I still haven't opened the box). I asked the seller in this case Staples, if I could look then return, they said No. Is it worth buying from a different retailer to confirm new engines? or is this over blown concern?
DON'T use the wrench to tighten your props. It is only to be used for removing stubborn props after a crash etc.I Got the metal tool with my P3A. I did not use it to install the props. After I got my hard carry case, I had to take the props off after 10 flights to get the P3 in the case. I was surprised at how easy the props were to unscrew off the motors. Concerned me! Now I use the metal tool to install the props every time.
When the P3 is powered up, the motors spin up for an instant, twice every time, like blipping the throttle. I have never heard any one report on this, but I'll bet it's to tighten the props.
But due to aggressive control input by ether the operator or the machine itself, as when it decelerates, props can loosen.
