New E305 Propulsion System
DJI is pleased to present the latest evolution of our Tuned Propulsion System series - the E305.
Finely customized and painstakingly engineered, the E305 Tuned Propulsion System is specifically designed for multirotor copters weighing 2.2-5.5 pounds (1-2.5 kg).
Combining increases in efficiency with proven, classic components, the E305 system provides maneuverability, stability, and efficiency in a highly cost-effective package.
Next Generation Motor
Built with improved manufacturing techniques, the brand new 2312E motor represents a significant upgrade over the previous 2312 model. The optimized electro-magnetic system boosts efficiency by nearly 7% and lowers cogging torque, which provides noticeably smoother performance at low RPMs. A newly designed motor base not only provides better heat dissipation, but also a more advanced, hi-tech look.
420 LITE ESC – Tried and Tested
The 420 LITE ESC utilizes the tried and tested square-wave drive architecture, further perfected by DJI engineers. Based on this classic design, the 420 LITE provides simplified functions in a much smaller and lighter package than the E310. Internally, an efficient and responsive algorithm is hard at work to provide your platform with a level of maneuverability and stability that belies its size.
Z-Blade 9450 Propellers
Another masterpiece by DJI Propulsion Laboratory. Aerodynamically optimized and precisely manufactured, the Z-Blade 9450 propellers produce powerful thrust with excellent dynamic balance. These reliable blades easily handle your FPV and other payloads while keeping your platform stable and virtually vibration-free, helping reduce the chance of jello or other unwanted effects.
Click here to learn more
tom sauter
