P3 not responding ??? Strange?
Was flying my P3 today and noticed my drone wouldn't respond to forward movement with the right joystick. It would yaw left and right and backwards. It happened on a small hill that my drone was moving past. I even turned the drone and tried to yaw into where I was wanting to go but nothing. I ended up landing, resetting everything and tried again with same results. It was pretty weird, almost like there was an invisible line that it wouldn't cross. Any thoughts?
Beginner mode or you have 'max distance enabled' and you have reached that distance limit. Disable that setting and have another crack.
Ummmm, no where near a NFZ? Have you tried another area to prove that and maybe turn beginner mode off and set your distance at 100 mtrs but keep it close. Were you running in simulator mode earlier and maybe have not exited it before going into live screen.
Not sure, bit I will check again. Had another flight in another area, no issues.
Scav8tor
