Meta4
Premium Pilot
- Joined
- Jan 8, 2014
- Messages
- 15,388
- Reaction score
- 9,341
And what kind of data do you imagine they are accessing?very simply, they are accessing data, and don’t want liability of being hacked.
True story...us Govt doesn’t use USB memory sticks...makes had embedded malicious code...only the niave fluff this off...it’s fact, it’s real.I bet your PC/phone/router/etc are chinese made or with chinese components. Do you worry about your security. furthermore, i bet your underwear and clothes are made in china, do you worry about the chemicals did to your body?
Whatever you give them access to via your controller IT device...of course.And what kind of data do you imagine they are accessing?
By the way, stepping out for a night flight be back in an hour or so...And what kind of data do you imagine they are accessing?
Its your rumba vacuum you need to worry about. It’s uploading the layout of your home.
It would be unreasonable to assume that they would be collecting the video.Your claim that “AeroScope does not capture video part”.
The DJI AeroScope white paper claims that the system captures radio frequency transmission to local receivers using existing UA antennas and modified C2 or video link protocols including one or more open standards (presumably 802.11 and/or WiFi broadcast protocol for DJI products. It is also separately revealed that the telemetry data is acquired directly from the video downlink stream.
It is evident that the video downlink is what is used by AeroScope to obtain the telemetry so it wouldnt be unreasonable to suspect the video might be available.
We are likely at crossed purposes here. ToIt would be unreasonable to assume that they would be collecting the video.
- The video feed is encrypted and is a separate data stream from the telemetry data
- Assuming they could decrypt the video stream, it's not a 4K stream. It's a lower resolution feed with a lower bitrate.
- No one wants to see your video, his video, my video. It's not that important.
As always ...a pleasure talking with youI've heard these wacky conspiracy theories a hundred times and they just don't stack up.
DJI aren't interested in your personal data or your images or videos.
The DJI app allows for two-way communication to allow for checking of firmware updates etc but that's about it.
If you have some reason to want to be super secret, it's easy enough to fly with a wifi only tablet anyway.
At a technical level, DJI could capture the video stream. DJI has not released any information to indicate that the AeroScope system could or would capture video.We are likely at crossed purposes here. To
Be clear I am not suggesting DJI might have a particular interest in collecting our downlinkwd video.
I have an interest in the technical implementation of Awroscope. Your claim that aeroscope does not capture video caught my attention, purely as I was interested to learn what, if anything, you knew about the actual operation of the system.
The telemetry is in fact part of the FPV downlink. From the white paper it is evident that the FPV downlink also contains other data including the AC S/N and the homepoint.
As to you your observations concerning the encryption, if the DJI can strip out the telemetry (we know it is sent in the same data stream as the video) why might you suspect the video would not be available? Clearly it must be.
We are back to (or probably best described as still at) where we started- all I was saying is that it would be seemingly possible to capture the video. Agreed the detail is scant, that is typical of DJI though.At a technical level, DJI could capture the video stream. DJI has not released any information to indicate that the AeroScope system could or would capture video.
Worked with the IRobot folks (makers of the Roomba) of course are an American company who built one of the first ground combat drones... If memory serves me correctly it was called the GATOR....it went crazy in the field with a M60 light machine gun mounted on it, when some Raven class iv drone RF cosite interference took it over...that was fun figuring that one outIts your rumba vacuum you need to worry about. It’s uploading the layout of your home.
There is no mechanism that brings our telemetry data off our machines to DJI.
Your Phantom and controller have a range of only a few kilometres.
How do you think they could send your telemetry to DJI and why do you think DJI would have any interest in your telemetry?
That's like saying that everyone in the US is just like the president.They are communist Chinese and everything they do is for some advantage for them. Who knows why and DJI will never tell. (Anything)
