No video output
Hi,
Happened today, was flying and filming and everything was ok. Changed battery, switched on Phantom, no video output from gopro. Switched off then on, nothing changed.
I tried however to film, but gopro started recording and stopped itself after 6 seconds.
So, no video output, no recording.
I updated the gopro, now filming is ok but no video output from the Zenmuse, or the gopro.
I have to sort this.
Fatshark transmitter works, fatshark receiver too.
Anyone faced this?
How do you know the FatShark works? I would trace the wires and look for bad solder joins, shorts, etc. Check the ribbon cable to the gimbal for physical damage.
Hi,
I know that Fatshark works cause I connected his camera and transmit correctly.
I think the problem is between the gimbal and the Phantom's board.
I updated the GoPro and seems to work, now.
